More switches are connected into the stack than are supported by the system. The stack will not operated correctly in this state.
Disconnect switches in the stack so that it contains no more than the maximum supported. It may be necessary to reboot the entire stack after doing this.
Warning
The maximum of %max% supported nodes in a stack has been exceeded.
| Name | Type |
| max | uInt |
